5 members (Otto Skorzeny, 2-Ton, Wally / Montana, Lightholder's Dad, 1 invisible), 117 guests, and 0 robots.
Topics128,051
Posts1,055,730
#8745 12/06/2001 4:13 PM
any one put tapered roller bearings in a front axle on a 3/4 ton?using the original front hubs? any advice on which kind of bearing work the best.and do you need special races any one have any info thanx
#8746 12/07/2001 4:06 AM
Moderator
Moderator
2 Online: Content
I put new front bearings in my 6400 this
fall that had the barrel shaped bearings.
The best parts man in this area side that
tapered was the way to go.Had to replace
both the races and bearings.They went to
gether just fine and adjusted and spun
normal.A good parts man can get you the
same dem. tapered bearings.
DON
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
#8747 12/07/2001 4:19 PM
W Online: Content
There was a pretty good posting on this subject a while ago. I think a Timken Bearing fellow said "why change them?" He gave reasons for keeping the ball bearings (run cooler, etc.). I've driven my '48 3/4T daily for 9 1/2 years on the ball bearings (max. 45 MPH, though). Of course, if they got completely trashed, I'd consider going to rollers if they were cheaper.
#8748 12/08/2001 5:24 AM
Moderator
Moderator
2 Online: Content
Wally
There's a differance between ball bearings,
tapered roller bearings,and barrel shaped
bearings. I've never seen ball bearings
on a spindle before.
Am I missing something in my life?
I went with tapered roller bearings
because every car/truck/trailer I've
worked on has always had tapered bearings
until this "50" 2-Ton.
There must be a reason.
fittyfive
Unless your a diehard keep it original
fan, I'd go with the tapered roller
bearings.
DON
"The Flag Pole"
1953 1-ton pickup
#8749 12/08/2001 6:12 AM
When I rebuilt the front end on my '51 GMC 2 ton, I had to replace one of the bearings. Timken no longer produces "tapered" or barrel shaped roller bearings. I had to order a "retrofit" to a tapered bearing and it cost almost $300 (from Timken) and that was for the small bearing. I was unable to obtain grease seals, so I had to re-use them. Anyone know of a source? I need to re-pack them soon, it has been almost 4 years and 3k miles!
*** GMC ***
#8750 12/08/2001 6:01 PM
W Online: Content
fiftyfive and 2-Ton, I'm one of the slowest ones in these forums and I'm doing less work on my '48 3/4T than practically anybody, but I've got ball bearings up front. They sell ball bearing replacements and show pictures at http://www.americanclassic.com/. There are also roller bearing/race conversions for a bit cheaper. Are we talking about the same thing?
#8751 12/09/2001 1:46 AM
Wally, the ball bearing replacements are readily available, as well as the grease seals for 1 ton and lower models. The heavier trucks got the "barrel" type tapered roller bearings eek .
*** GMC ***
#8752 12/10/2001 2:21 AM
Moderator
Moderator
2 Online: Content
I've never seen or heard of roller bearings
on front spindles before. Thats why this
site is so good,there's not a single time
I've been here and have not learned at
least something. Thanks for the info.
DON
"The Flag Pole"
1953 1-ton pickup
