3 members (Rich'sToys, Nick in Manitou, Bill Hanlon), 88 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#874645 08/14/2012 9:53 AM
got a oil leak comming from harmonic balancer, anyone got any info on removal of balancer and replacement of seal or packing?
I am going to guess that the seal with packing can be replaced with a modern type seal.
1951 1 Ton Completed
The original seal was a cork disc, with an oil slinger between it and the timing gear. It might be possible to machine the timing cover to accept a conventional lip seal, if you can find one that will fit the balancer hub. It might also be necessary to machine and/or polish the hub snout to use a lip seal on it.
To remove the HB you must pull it off via the two threaded bolt holes. The 207 HB is made in two pieces and can be damaged if pulled off using a regular jaw type puller.
During installation you must install two cap bolts to hold the two halves together before you drive it on. Don't forget to remove the bolts after it's installed.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
