| | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | got a oil leak comming from harmonic balancer, anyone got any info on removal of balancer and replacement of seal or packing? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am going to guess that the seal with packing can be replaced with a modern type seal. | | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | The original seal was a cork disc, with an oil slinger between it and the timing gear. It might be possible to machine the timing cover to accept a conventional lip seal, if you can find one that will fit the balancer hub. It might also be necessary to machine and/or polish the hub snout to use a lip seal on it. Jerry
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | To remove the HB you must pull it off via the two threaded bolt holes. The 207 HB is made in two pieces and can be damaged if pulled off using a regular jaw type puller. During installation you must install two cap bolts to hold the two halves together before you drive it on. Don't forget to remove the bolts after it's installed. Mike B  | | |
