4 members (qside, GrandpasJimmy, GRNHydra, Rnl364), 87 guests, and 2 robots.
Topics128,064
Posts1,055,859
Members48,428
#874408 08/13/2012 11:53 AM
Oil drain plug leaks, threds look and fill good.Oil heats up it drips evon more.Any quick fixes. thanks
Ex Hall Monitor
Ex Hall Monitor
There should be a crush washer on the plug I believe, made from copper if I remember right. A replacement plug should have on one it or you should be able to go to the hardware store and get a new washer for your current plug. Looks kind of like this.
oldchevyguy -
Will you please post the source when you find a crush washer that Tiny described. I need one, too.
- Lonnie
My '54 3104
For what its worth, you can pick up a new plug and washer on just about any of the usual virtual stores as well as any brick and mortar auto parts place for a couple bucks.
I would just replace the entire thing if it's old and leaking. ...could also be your pan threads.
BLUEMANIE - That's too simple. Sometimes the obvious just has to slap me in the face!!
Which of these NAPA oil drain plugs is closest to the original plug in a '54 235? I know they all probably work and no one will ever see it but me; just trying to satisfy my "picky gene."
< CLICK > NAPA oil drain plugs
- Lonnie
My '54 3104
Ex Hall Monitor
Ex Hall Monitor
Wait 'til the next oil change and take yours with you when you go to buy oil and a filter.
I'll do so when I change the oil next month. The plug fits the pan, but I don't know if it was the original one. No oil filter ... I just change the oil more often.
- Lonnie
My '54 3104
Lonnie - Been there, done that! Hahaha
If you want exact, one of the online stores lists one with a picture as an "exact replacement for the original" ... Carter or Classic maybe, can't remember offhand.
Well, I didn't see an "exact replacement" at the usual on-line suspects. But I did learn what single-, double-, and triple-oversize mean.
< CLICK > Drain plug definitions
As usual, I'm overthinking a simple task. I'll try a gasket first, then a new plug if needed at the next oil change.
oldchevyguy: Sorry for hijacking your thread.
- Lonnie
My '54 3104
I have seen plug washers that are made to flex and have rubber inside. They would seal without much effort I would think.
1951 1 Ton Completed
Good in theory, but they just don't work. A hard nylon or copper drain plug gasket, combined with a smooth, flat surface to seal against is the best of all possible situations. I like to draw-file the pan area around the plug to make sure there's not a pulled thread or other irregularity that prevents the washer from getting a good seal.
