7 members (Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, Phak1, 1 invisible),
44
Mod | | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Oil drain plug leaks, threds look and fill good.Oil heats up it drips evon more.Any quick fixes. thanks | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There should be a crush washer on the plug I believe, made from copper if I remember right. A replacement plug should have on one it or you should be able to go to the hardware store and get a new washer for your current plug. Looks kind of like this.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | oldchevyguy -
Will you please post the source when you find a crush washer that Tiny described. I need one, too.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | For what its worth, you can pick up a new plug and washer on just about any of the usual virtual stores as well as any brick and mortar auto parts place for a couple bucks.
I would just replace the entire thing if it's old and leaking. ...could also be your pan threads. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | BLUEMANIE - That's too simple. Sometimes the obvious just has to slap me in the face!! Which of these NAPA oil drain plugs is closest to the original plug in a '54 235? I know they all probably work and no one will ever see it but me; just trying to satisfy my "picky gene." < CLICK > NAPA oil drain plugsThanks,
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Wait 'til the next oil change and take yours with you when you go to buy oil and a filter.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I'll do so when I change the oil next month. The plug fits the pan, but I don't know if it was the original one. No oil filter ... I just change the oil more often.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Lonnie - Been there, done that! Hahaha
If you want exact, one of the online stores lists one with a picture as an "exact replacement for the original" ... Carter or Classic maybe, can't remember offhand.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Well, I didn't see an "exact replacement" at the usual on-line suspects. But I did learn what single-, double-, and triple-oversize mean. < CLICK > Drain plug definitionsAs usual, I'm overthinking a simple task. I'll try a gasket first, then a new plug if needed at the next oil change. oldchevyguy: Sorry for hijacking your thread.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have seen plug washers that are made to flex and have rubber inside. They would seal without much effort I would think. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Good in theory, but they just don't work. A hard nylon or copper drain plug gasket, combined with a smooth, flat surface to seal against is the best of all possible situations. I like to draw-file the pan area around the plug to make sure there's not a pulled thread or other irregularity that prevents the washer from getting a good seal. Jerry
