2 members (mick53, J Lucas),
133
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87430 07/16/2004 6:23 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | I am putting a tilt steering column into my '66 C10. I am wondering what I need to get 4 way hazard flashers. The column is from a '79 and I have the wiring harness with connectors. The brown wire on the new column harness is for the hazard flasher unit. Do I need a relay or anything else to wire it in, or do I just run the brown wire over to the fuse panel or ??????
John :confused:
Be Happy and Live a Good life filled with Love and Happiness.
#87431 07/16/2004 2:16 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Hook it to power all time thru a flasher. Brian | | |
#87432 07/17/2004 5:43 AM | Joined: Oct 2003 Posts: 38 Member | | Member Joined: Oct 2003 Posts: 38 | :confused: I'm sorry. I am a little dense. Can you be a bit more descriptive. I need things really spelled out for me. I want to make sure I don't burn something out from wiring it wrong.. :p
#87433 07/17/2004 6:42 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Let me see if I can help. Find a full-time power source and connect at a 12-14 ga wire to the power source on one end and the other end of the wire gets connected to one of the flasher terminals. Take another wire of the same gauge and connect to the other flasher terminal and connect the opposite end of the wire to the brown wire or terminal on the column connector that the brown wire attaches to and your done.
Joe
