2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I have a pcv valve and hose connected to the intake from the side of the valve cover. I also have a breather hose running from the top of the valve cover to the top of the air cleaner. There is a breather cap on the valve cover too. Is the breather cap on the valve cover creating a needless vacuum leak? I haven't noticed a difference in idle or performance. Just wondering if I should use a standard valve cover cap or does it matter if I'm venting in more air?
Thanks.
| | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | I'd ditch the vented cap, the fresh air via the air fiter is a sealed PCV system, as in any excess vapors that the PCV can't handle will be drawn into the carb (think high engine load / low manifold vacuum). A vent cap makes it an unsealed system, excess crankcase blow by out the vent cap. Also fresh air to crankcase via the engine air filter should be much cleaner that the mesh of the breather cap can offer.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I agree. I haven't noticed a lot of blow by so I left it on. But it isn't a fully sealed system the way it is now. Thanks. | | |
