0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 33 | i have a ? about my 57 chevy pickup if i swap in a 350 will the orignal 57 radiator still work to cool the 350 or will i need something else? thanks
1957 Chevy Service Station Wrecker
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy toychaser2005, was your truck originally equipped with a six cylinder or an eight cylinder engine? The eight cylinder truck had the radiator moved back closer to the engine. If your truck was originally equipped with a six cylinder, you will probably need a shroud or some fan spacers or both to get the fan to pull cooling air through the radiator properly. That being said I believe the stock rad in good condition should keep a 350 cool, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | X2 what 3B said, especially the shroud if it was originally a 6, then a good '57 rad with a 7# cap will work fine
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The answer to your question is a definite "maybe". As was mentioned above, an original-equipment V8 radiator in good shape should cool a stock 350 without much of a problem. If you add some "go-fast" goodies to it, you'll definitely need some more cooling capacity. The 600+ HP 350's we ran on the circle track needed a pretty hefty aluminum radiator, a good shroud, and a high-flow fan to keep 'em cool. Jerry
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I'm running a 350 with a comp 286 cam, headers, flat top pistons, etc. . Haven't dynoed it but guessing around 350 HP.
I'm using a stock radiator with a shroud and have absolutely no overheating problems - even in the 100+ temps we often have. | | | | | Joined: Jul 2009 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 33 | my truck had original 235 6 cyl if that help ill try the original an go from there thanks guys for the input an help
