2 members (Tronman, Gray_Ghost), 85 guests, and 1 robot.
Topics128,142
Posts1,056,476
Members48,441
I
I Offline
I bought an aftermarket 7 wire turn signal kit for my 51 GMC. I have wired up the 2 wire, stop, turn, tail lights and when I use either turn signal both rear lights flash. Where have I gone wrong?
Been a couple of years since I went thru that but what is happening is that both rear lights are tied together thru brake light switch. Instructions will tell you to cut a line going to brake switch and how it is rewired thru turn signal switch.
I
I Offline
Read the directions? What kind of bizarre, freaky suggustion is that? Actually you were absolutely correct. The mechanic connected from the brake switch to the turn signal as he should, but had left the wire from the brake switch to the brake lights connected and also had a hot wire connecting the two brake lights. We cut those two wires and it works perfectly.
Thanks for the quick response.
Izzy
