| | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87405 01/11/2004 8:23 PM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I bought an aftermarket 7 wire turn signal kit for my 51 GMC. I have wired up the 2 wire, stop, turn, tail lights and when I use either turn signal both rear lights flash. Where have I gone wrong? | | |
#87406 01/11/2004 8:29 PM | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Been a couple of years since I went thru that but what is happening is that both rear lights are tied together thru brake light switch. Instructions will tell you to cut a line going to brake switch and how it is rewired thru turn signal switch. | | |
#87407 01/12/2004 1:43 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Read the directions? What kind of bizarre, freaky suggustion is that? Actually you were absolutely correct. The mechanic connected from the brake switch to the turn signal as he should, but had left the wire from the brake switch to the brake lights connected and also had a hot wire connecting the two brake lights. We cut those two wires and it works perfectly.
Thanks for the quick response.
Izzy | | |
