Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (SWEET, Wickedbass, Hanks custodian, HandyAndy, Ponchogl), 40 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#874003 08/11/2012 8:05 PM
i have a ? about my 57 chevy pickup if i swap in a 350 will the orignal 57 radiator still work to cool the 350 or will i need something else? thanks
1957 Chevy Service Station Wrecker
toychaser2005 #874033 08/11/2012 10:06 PM
3B Offline
Hy toychaser2005, was your truck originally equipped with a six cylinder or an eight cylinder engine? The eight cylinder truck had the radiator moved back closer to the engine. If your truck was originally equipped with a six cylinder, you will probably need a shroud or some fan spacers or both to get the fan to pull cooling air through the radiator properly. That being said I believe the stock rad in good condition should keep a 350 cool, hope that helps.
3B #874037 08/11/2012 10:14 PM
X2 what 3B said, especially the shroud if it was originally a 6, then a good '57 rad with a 7# cap will work fine
toychaser2005 #874053 08/11/2012 10:44 PM
The answer to your question is a definite "maybe". As was mentioned above, an original-equipment V8 radiator in good shape should cool a stock 350 without much of a problem. If you add some "go-fast" goodies to it, you'll definitely need some more cooling capacity. The 600+ HP 350's we ran on the circle track needed a pretty hefty aluminum radiator, a good shroud, and a high-flow fan to keep 'em cool.
Hotrod Lincoln #874131 08/12/2012 11:52 AM
I'm running a 350 with a comp 286 cam, headers, flat top pistons, etc. . Haven't dynoed it but guessing around 350 HP.
I'm using a stock radiator with a shroud and have absolutely no overheating problems - even in the 100+ temps we often have.
Avette4me #874494 08/13/2012 5:13 PM
my truck had original 235 6 cyl if that help ill try the original an go from there thanks guys for the input an help
