8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 60 | after a exausting afternoon working on the 59 viking brakes and a few chats with mike we determind that a rear brake hose was bad on my bolt. ok.. changed all the hoses yeah it needed it anyway. all seemed good bled felt perfect then....after starting the ol gal i move forward and applied the brakes stopped perfect then i noted it felt like the parking brake was on truck will move but binds like still applied.The truck has a addapted later brake booster and master guessing 64 65 truck could this be the binding problem? its sticking engauged? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Take the vacuum off of the booster to see what it does...it might be leaking internally, Scott | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your master cyl. rod probably needs adjusting. It is not going back far enough to release the brakes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
