2 members (1955 1 Series, Peggy M), 115 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#873726 08/10/2012 1:12 PM
mj
Offline
does the bee hive style oil filter need a gasket between the lid and body? mine leaks out when the engine is running. 235 newly rebuilt and installed. it is the smooth body not the oil filter body with the ridges. I don,t see any in the parts books. Thanks for all your help , on this and all the answersin the past, mj.
mj #873728 08/10/2012 1:25 PM
Hi MJ,
Yes there is a gasket that goes between the lid and the body of the filter. I have a similar set up on my 51 216. Last time I changed the oil and filter I believe the new filter came with a gasket.
Good luck.
Chris
If you need one a old inner tube might be willing to recycle itself into a new function.
Give me ambiguity
or give me something else
CASO #873799 08/10/2012 6:12 PM
Riding in the Passing Lane
Be careful useing other materials for important gaskets. The hot oil could ruin that old rubber & you can wind up ruining an engine.
1972 Chevy c10 Cheyenne Super
I have used the WIX website in the past to find cover gaskets. All you need is the O.D and I.D. and these gaskets are available at most NAPA stores I believe or take the measurements or cover in and have them find the correct one.
Ed
