2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | does the bee hive style oil filter need a gasket between the lid and body? mine leaks out when the engine is running. 235 newly rebuilt and installed. it is the smooth body not the oil filter body with the ridges. I don,t see any in the parts books. Thanks for all your help , on this and all the answersin the past, mj. | | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | Hi MJ,
Yes there is a gasket that goes between the lid and the body of the filter. I have a similar set up on my 51 216. Last time I changed the oil and filter I believe the new filter came with a gasket.
Good luck.
Chris | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you need one a old inner tube might be willing to recycle itself into a new function.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Be careful useing other materials for important gaskets. The hot oil could ruin that old rubber & you can wind up ruining an engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I have used the WIX website in the past to find cover gaskets. All you need is the O.D and I.D. and these gaskets are available at most NAPA stores I believe or take the measurements or cover in and have them find the correct one.
Ed
