2 members (Opelika Tom, baldeagle), 116 guests, and 1 robot.
Topics128,037
Posts1,055,469
Members48,424
#873501 08/09/2012 6:14 PM
As some of you may know Ive had a problem with th fuel sender in my 54 gmc. I got that taken care of with the new install of a VDO fuel sender that works hand in hand with VDO fuel gauge. The new sender didnt have the port for the fuel line. How would i go about converting it into a gravity feed fuel system or what other option do I have??
54GCPGMC #873513 08/09/2012 6:41 PM
Can I add an inline electric fuel pump powered off of the ign so it would shut when the truck shuts? Mechanical pump is still in working condition
54GCPGMC #873519 08/09/2012 7:06 PM
54GC, you would need to add a relay that gets power when the key is on, not necessarily from the ignition. the other two connectors -one comes directly from the battery the other goes to the elec fuel pump. Should be a picture on the new one.
Relay avail,Aotozone ,Orielly,etc
edit-if your system is 12 VDC
old guy with old trucks
chuck2213 #873527 08/09/2012 7:28 PM
would this be a better option then running it by gravity?
54GCPGMC #873543 08/09/2012 8:26 PM
an electric pump is an option, but you could also find an earlier tank with the bottom outlet .... a bottom outlet tank doesn't really run by gravity, the mechanical pump has suction, that's why the top outlets work as well .... how is it working now if the sender doesn't have the outlet fitting?
Flxible #873546 08/09/2012 8:30 PM
its not working right now. could i drill a hole on top and run a line in the tank? similar to previous sender?
54GCPGMC #873554 08/09/2012 8:52 PM
should work if you use the tube and filter sock from the original and can seal it properly so you don't have fumes in the cab .... it needs to accurately reach the bottom of the tank
Flxible #873707 08/10/2012 11:36 AM
did what you said works great so far. thanks
54GCPGMC #874369 08/13/2012 9:39 AM
Can you modify the new sender to include the fuel suction line?
If not I'd look for a sender that incorporates the suction line as it was stock.
As another option you can modify your tank to have a suction tube or drain wherever you please.
The fuel sender system I've used many times looks like a 5 gallon can of fuel, it goes in the bed. When the tank is low on fuel the engine makes a distinct sputtering sound, at that point you cut the ignition and pull over preferably on the left side of a hill such that the filler neck is high, makes it easier to pour the fresh fuel in without a funnel....
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #875478 08/17/2012 12:20 PM
Crusing in the Passing Lane
I have a cheap fuel sender, hardware stores give away yard sticks, 1" = 2.5 gal.
EdPruss #875742 08/18/2012 11:01 AM
haha. awesome.
