3 members (78buckshot, Phak1, Gdads51), 81 guests, and 2 robots.
Topics128,093
Posts1,056,475
Members48,444
#873410 08/09/2012 12:01 PM
I have a small leak that looks like it's coming from the pinion seal flange area. I have a 1950 3600. I do not have it apart yet.
A few questions please. I assume I can remove the drive shaft yoke, then the bolts that hold the flange in place.
Is the seal in fhe flange?
Is there a 'crush' washer and/or pre-load?
NAPA lists a rubber seal for $23 (part number 25970) I believe it's a SKF seal. Any experience with it?
Thank you.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Riding in the Passing Lane
You have it right. Pull the yoke & flange. The seal goes in from the back side of the flange. There is no crush sleeve on this. Tighten it plenty tight & then go further to line up the cotter pin hole. The Napa seal should be OK. I prefer Nationa seals. There is a gasket in back of the flange. You can use RTV but put on a good bead as the flange does not go flush up to the houseing.
1972 Chevy c10 Cheyenne Super
Thank you. It will be done...
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
