1 members (1 invisible),
91
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I have a small leak that looks like it's coming from the pinion seal flange area. I have a 1950 3600. I do not have it apart yet.
A few questions please. I assume I can remove the drive shaft yoke, then the bolts that hold the flange in place.
Is the seal in fhe flange? Is there a 'crush' washer and/or pre-load? NAPA lists a rubber seal for $23 (part number 25970) I believe it's a SKF seal. Any experience with it?
Thank you. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have it right. Pull the yoke & flange. The seal goes in from the back side of the flange. There is no crush sleeve on this. Tighten it plenty tight & then go further to line up the cotter pin hole. The Napa seal should be OK. I prefer Nationa seals. There is a gasket in back of the flange. You can use RTV but put on a good bead as the flange does not go flush up to the houseing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thank you. It will be done... | | |
