7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 5 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 5 | I have a 1962 C10 and I found a 1963 C10 for cheap. My doors are bad and I was going to swap them out. My question is does sheet metal parts, doors, etc. interchange with those years?
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | the doors will fit your 63, doors are the same 60-63 chevy or gmc.some have a frame around the door glass and some dont.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The sheet metal items are interchangeable, between the 60-'63 Chevy and GMC trucks, with the exception of the dash board for the Chevy, is different from the GMC, but will interchange. The '60-'62 truck frames are wider, than the '63-'66 truck frames, so the mounting locations of the front & rear frame-to-cab supports do not line up. Although the windshield/A-pillar changed in 1964, the frame style changed in 1963.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | The sheet metal items are interchangeable, between the 60-'63 Chevy and GMC trucks, with the exception of the dash board for the Chevy, is different from the GMC, but will interchange. The '60-'62 truck frames are wider, than the '63-'66 truck frames, so the mounting locations of the front & rear frame-to-cab supports do not line up. Although the windshield/A-pillar changed in 1964, the frame style changed in 1963. Tony on the 60-62 where does the width differential take place in the frame. the front section is the same as the later ones is it not. the rear of the earlier frames are about 42". the position where the frt cross member(2 wheel drive)goes in is the same right up to 87 is it not. just curious ron | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | On the '60-'62 Chevy trucks, the cab mounting & rear frame rail dimensions are:
Front frame-to-cab perch, center-to-center width, is 51-1/2" Rear frame-to-cab perch, center-to-center width, is 41" Rear frame width at frame rail end, is 42"
On the '63-'66 Chevy truck, the cab mounting & rear frame rail dimensions are:
Front frame-to-cab per, center-to-center width, is 42" Rear frame-to-cab perch, center-to-center width, is 41" Rear frame width at frame rail end, is 34-3/4"
