3 members (Gdads51, Gib70, 1 invisible), 86 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
#872715 08/06/2012 9:26 PM
I have a 1 ton 1948 chev panel with a 4.56 differential. Is there a ring and pinion set for this so I can get more than 45 mph.
first48 #872717 08/06/2012 9:28 PM
Nothing that's being produced at thsi time. Only option beyond swapping out the rearend entirely would be to find the 4.10 third member that was an option in '68-'72 3/4 tons.
Bill Burmeister
LONGBOX55 #873412 08/09/2012 12:05 PM
An OD transmission swap is another way to crack the 45 mph barrier. You will likely also have to swap a full pressure 235 for your tired 216 to get the benefit of OD.
The 1 ton may have 5.13 gears, so switching to the higher 4.56 3/4 ton gears may give you some improvement. Double check the actual ratio, and play with the online gear calculators to see what rpm your truck is spinning at current speeds.
Id double check the gear ratio that you have now, with 4.56's you should be able to go faster than 45. im guessing at least 55-60.
I know that the bigger trucks like my 2&1/2 ton which has 6.33 gears, the top speed was 45, but they also have taller tires which makes a difference.
If you do actually have 4.56's try a taller tire. They will make a difference.
