8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I have a 1 ton 1948 chev panel with a 4.56 differential. Is there a ring and pinion set for this so I can get more than 45 mph. Thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Nothing that's being produced at thsi time. Only option beyond swapping out the rearend entirely would be to find the 4.10 third member that was an option in '68-'72 3/4 tons.
Bill Burmeister | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | An OD transmission swap is another way to crack the 45 mph barrier. You will likely also have to swap a full pressure 235 for your tired 216 to get the benefit of OD.
The 1 ton may have 5.13 gears, so switching to the higher 4.56 3/4 ton gears may give you some improvement. Double check the actual ratio, and play with the online gear calculators to see what rpm your truck is spinning at current speeds. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Id double check the gear ratio that you have now, with 4.56's you should be able to go faster than 45. im guessing at least 55-60.
I know that the bigger trucks like my 2&1/2 ton which has 6.33 gears, the top speed was 45, but they also have taller tires which makes a difference.
If you do actually have 4.56's try a taller tire. They will make a difference.
