2 members (Hanks custodian, 1 invisible),
124
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | I have searched and read previous posts but all seem different. What is the easiest and best pcv valve install to replace the draft tube on my 228 gmc engine? | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | If you do look up the Smog system requirements they weren't enacted until long after the 228-248-270-302's were built. But later in my state we started to have to add and modify a system on our older engines. Why not try a good Parts House and ask them if a kit is available and then ask this question. I had a dual quad Chev 283 and the required Smog add-on really caused me some problems. Normbc9 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The easiest would probably be the stock system off a 2-ton or larger GMC of the era. I used one off a '59 on my 248 and it has a paper air filter. Earlier '50s ones were oil bath. pic1 pic2 | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | in addition to what cletis said, you will also need the valve cover, oil fill/breather pipe to replace draft tube, pvc pipe and the vacuum manifold that screws into the intake manifold plus the pvc valve to make it look oringinal. i got one from a 46 350 (two ton) and put it on my 40's 270. | | |
