10 members (Donf, Bogart's Truck, jmoore, Gdads51, TexasA&M48Truck, kades51, Otto Skorzeny, Frank50, Jon G, 1 invisible), 105 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
#872839 08/07/2012 9:54 AM
I have searched and read previous posts but all seem different. What is the easiest and best pcv valve install to replace the draft tube on my 228 gmc engine?
1 Offline
If you do look up the Smog system requirements they weren't enacted until long after the 228-248-270-302's were built. But later in my state we started to have to add and modify a system on our older engines. Why not try a good Parts House and ask them if a kit is available and then ask this question. I had a dual quad Chev 283 and the required Smog add-on really caused me some problems.
Normbc9
The easiest would probably be the stock system off a 2-ton or larger GMC of the era. I used one off a '59 on my 248 and it has a paper air filter. Earlier '50s ones were oil bath.
pic1
pic2
Thank you
in addition to what cletis said, you will also need the valve cover, oil fill/breather pipe to replace draft tube, pvc pipe and the vacuum manifold that screws into the intake manifold plus the pvc valve to make it look oringinal.
i got one from a 46 350 (two ton) and put it on my 40's 270.
