4 members (HandyAndy, '37 barn find, cmayna, ESum), 117 guests, and 6 robots.
Topics128,210
Posts1,057,465
Members48,471
0
0 Offline
292 6 cyl. - I installed a new Chinese made exhaust manifold on my 292. I had to have the intake machined for smoothness where it meets the exhaust manifold. Consequently now the intake is too low to meet the ports & bolt holes in the head. Does someone make a spacer or thick gasket to compensate for this gap...I presently trippled up 3 gaskets with silicone, kinda poor repair, but I can't think of anything else...Would like to repair it correctly...Thanks
How thick does it need to be -- 16 ga? 12 ga?
You should be able to make one yourself with a jig saw.
Just use the gasket as a template.
Sheet metal from Tractor Supply
regards,
Leon
0
0 Offline
Thanks for your reply Leon....was trying to find something already made if possible..
