0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | So, I have a door window with a frame on the drivers side and one with out a frame on the passenger side on my 61 1/2 ton SB step, which is correct? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The medium-duty & heavy-duty trucks from '60-'63, commonly had the metal frame. On occassion, we find a light-duty truck with a window glass with the frame, as well. Some frames are painted black and some are chrome, so it can have glass with or without a frame...it is a matter of preference.
| | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok, thank you for the information Tony | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | All of the 1961 trucks that I have owned/own (4 total)have had the window frames. 3 were Chevrolets and one was a GMC. One was a one ton Chevy series 30. And the others were all half tons. I have looked at many 60-63 trucks over the years and honestly can't remember one that did NOT have the window frames. I do realize that it was "optional" to not have the frames, I just can't recall seeing one without them. (my use of the word optional is meant as "possible", not as an RPO) | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We have shelled alot of '60-'63 Chevy & GMC doors and seen many with and many without, so I am not sure the driving factor on whether the door glass had frames or not. I am interested in knowing the reason, as well.
| | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Maybe the Trim Level? Maybe pre early '63-post late '63? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Great point and much appreciated.
| | | | | Joined: Oct 2008 Posts: 2 New Guy | | New Guy Joined: Oct 2008 Posts: 2 | My 1961 1/2 ton Apache 10 had black window frames and it was a custom cab truck from California. Maybe is was an assembly plant thing. Different assembly plants might of had different supplier sources.
1966 c-10 LWB custom cab
