| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87276 12/07/2002 5:21 AM | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | I have a 1954 chevy 3/4 ton 6 volt. The amp gauge does not move toward charge at all, but goes to dis charge when the lights are on. I can run about a month before I have to use a batter charger If I don't run the lights. Some of the wireing is pretty bad under the truck. So I was thinking now would be a good time to rewire and upgrade to 12 volts. But I am afraid I will screw it up. Is it possible for someone who does not know anything to do this, if so HOw? When? how much? and it not, where can I get it done? Thanks :p | | |
#87277 12/07/2002 7:42 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I ordered a 12v wiring harness from Chevy Duty, it came numbered and color coded and simple enough to do in one day.
Do you want to change your truck to 12v or keep it original? They have 6v harnesses with heavier wire, so test the generator and regulator before you commit to all new hardware.
Here's what I ended up with:
90-amp internally regulated alternator 12v Interstate battery 12 to 6 voltage drop resistor, coil 12 to 6 voltage drop resistor, fuel gauge 12v halogen headlights 12v bulbs for tail, marker, dome and dash lights 12v cigarette lighter 12v heater fan 12v wiper motor (am I forgetting anything?)
You're going to need wire cutters/strippers and a pile of connectors (I used crimp sleeves in some places, spade connectors in others). You may or may not need a side-terminal style starter switch, I didn't use one and it works fine.
On the downside, my fuel gauge reads high because I'm still using a 6v sending unit. The benefits are I can put any modern equipment in the truck (stereo, power seats, electric wipers, etc) and stuff like cell phones and laptops plug in to the dash.
Make a list of electrical components that need to be replaced; it may affect your decision.
Edit: I forgot the fuseblock I added for all the new stuff. :p | | |
#87278 12/07/2002 5:52 PM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | funtime: Here's a site with some helpfull info. Check it out. http://www.telusplanet.net/public/ddness/index.html
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
#87279 12/07/2002 8:36 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Cool link Wingnut-why not submit that to the "Powers That Be" here at Stovebolt-it SHOULD be on our permanent links list! Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#87280 01/21/2003 11:57 PM | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | Hi,Thanks for the info. I am real slow at responding but I have a question? What is the difference in the $100.00 wiring harness and the $300.00 harness? and is it really as simply as it seems? If I buy a one wire alternater do I need a new bracket? | | |
#87281 01/22/2003 12:43 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Originally posted by funtime: What is the difference in the $100.00 wiring harness and the $300.00 harness? $200. Seriously, the high dollar harness comes with all the extras you'll need for A/C, electric fans/wipers/windows and all the stereo equipment anyone would ever need. You get all the connectors and (I believe) a large fuse block with modern spade-type fuses. I went with the cheap one since I plan to have all (non-motor) accessories on a separate power source. And yes, they really are easy to install. Match the numbers, follow the colors; and you're done. I fabricated a new mount for my alternator from 1/4" straight stock and a hunk of angle iron. One of the water pump bolts holds the top bracket. I'm sure somebody makes the right item, but I'm cheap and the raw material was right there.... | | |
#87282 01/22/2003 6:23 AM | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | Yea $200.00 I guess I walked into that one. I am guessing the $300.00 is worth the extra money  why the seperate power source? Are you going to use 2 batteries? | | |
#87283 02/10/2003 8:23 AM | Joined: Nov 2002 Posts: 28 Junior Member | | Junior Member Joined: Nov 2002 Posts: 28 | I recomend against crimp lugs, as they tend to detirorate quickly. Unless you have a proffesional crimping tool, it's also easy to over crimp, or crimp them wrong, and then it's even worse. They're also open, so the connections tend to corrode. I recomend you solder all the connections, then either wrap in electrical tape, or even better, use heatshrink tubing. If you do it this way, the wiring will probably outlast the truck.
As to the $100 vs 300, the difference is probably in quality. The cheap one likely uses cheap wires and connections, and will not last. The more expensive one will most likely use a thicker insulation, and better connections. The cheap one may also not have all the options, and could fit poorly. I once rewired a vw bug using a cheap harness, and the harness fit very poorly. Half the conectors were either to short, or where in the wrong place, so I practically had to rewire the rewiring kit! Since then, I've done my own. Most of it is easy, probably more so with the older trucks. The tail lights are very easy, just 3 wires, and the engine harness isn't much worse. The only thing you'll have a bit of trouble with would be the dash harness, and even then, it's just a matter of tracing the old wires out, then replacing them. ~John
61 chevy c40 w/ holmes 400 wrecker bed. 350, 4spd, big window.
61 chevy c40 flatbed, rebuilt 327, 4spd, custom 12' flatbed. (for sale)
85 **** f250 diesel, c6, 3.31 rears
#87284 02/10/2003 5:43 PM | Joined: Oct 2002 Posts: 22 Member | | Member Joined: Oct 2002 Posts: 22 | Speaking of connectors, our local parts guys have some pretty trick ones. It's heat shrink, with solder in the middle. You just stick the wire ends in, hit it with some heat, and it solders and heat shrinks in one step. I'm sure you've seen 'em. Works great, only problem is it's a one shot deal. If you screw it up, the whole thing is wasted. They come in all sizes colors, shapes. Just a thought!
JAKE
1949 Chevy Styleline Coupe CARBOLT
#87285 02/12/2003 5:57 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Before you make your decision, contact Randy, moderator of this board fifthave@oz-online.net He has a booklet he put together that will help you out.
Fred 52 3600 69 C-10
