| | | Forums66 Topics128,050 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 21 New Guy | | New Guy Joined: Jun 2011 Posts: 21 | I came across for sale a 235 out of a '54 3100. My '52 3100 has the stock 216 so a future engine swap might be near. My question is which 235 is better? I'm pretty sure the '54 235 is full oil pressure but would a 235 from '55-61 be a better choice? Thanks guys for your input | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '54 235 is perfect for your swap. It already has the water pump in the correct spot, so no adapter or special water pump will be needed to fit it in. The '54 engine will be full pressure. If I'm not mistaken, I beleive you will need to use the 216 bellhousing to mount it in your frame. Otherwise, it should be a drop in.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Bill is correct on all points.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 21 New Guy | | New Guy Joined: Jun 2011 Posts: 21 | Thanks Longbox, hopefully I can pick this one up before it gets gone! | | |
