| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87255 11/09/2004 5:10 AM | Joined: Nov 2004 Posts: 3 Junior Member | | Junior Member Joined: Nov 2004 Posts: 3 | hey guys, I wasn't logged on when I sent this message the first time. Forgive me if it comes up twice. Having trouble with head lights tail lights and brake lights. when I step on the brake it blows a fuse. I can't seem to find a short anywhere. this is on a 64 chevy fleetside 230 6. Any advice would be helpful. Thanks
clint | | |
#87256 11/09/2004 6:13 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You definately have a short to ground somewhere. Do you have a multi-meter? You need to wring (check for continuity and grounds) your wires. I'd start on the wire from the switch to the tail/brake light connector. Unplug both ends. If it's not there then check from the connector to the light sockets. | | |
#87257 11/09/2004 6:13 AM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Clint: Wife says don't step on the brakes.
For a direct short: If you wire a bulb in place of the fuse, the light will illuminate as long as you have a short. Then you can move some wires around and find the area that has the direct short. (If the wire is up against the frame or somewhere like that, the bulb should go out when you move the wire away from the ground source.) Also, don't forget to test bulbs first, sometimes they are shorted in their sockets.
Try also the brake switch itself. (Bypass the switch by connecting just the wires to each other.)
Hope this helps. | | |
#87258 11/09/2004 11:48 PM | Joined: Nov 2004 Posts: 7 Junior Member | | Junior Member Joined: Nov 2004 Posts: 7 | CHECK THE PIG TAILS AT THE TAIL LIGHTS I FOUND THE SAME PROBLEM ON MY 51 MERC PICK UP THE SPRINGS THAT PUT PRESSURE ON THE BULB CONTACTS SLIPPED SIDEWAYS AND MADE CONTACT BLOWING TAIL LIGHT FUSE AND BRAKE FUSE.CHANGED THE SPRINGS FOR RUBBER TENSIONERS SOLVED THE PROBLEM
Richard Laszchuk
#87259 11/11/2004 4:05 AM | Joined: Nov 2004 Posts: 3 Junior Member | | Junior Member Joined: Nov 2004 Posts: 3 | I think I found the problem. It was in the pig tails at the tail lights. thanks everyone for your input. You really helped me out.
clint p.s. Oehm I think I missed spelled your name in the earlier reply. sorry. I haven't got this computer thing down yet. | | |
#87260 11/24/2004 4:49 AM | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | There is another possibility, although it is a rareity. You may have a tailight bulb that is grounding out internally. It's a one in a million chance but it happens! | | |
