0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#87252 07/04/2004 12:01 AM
Junior Member
Junior Member
I have an all original/original 1953 3800. My gas gage was working a few months ago and I just added 12 gallons and noticed the gage went only to 1/4. When driving home it came up briefly then dropped back down.
QUESTION -- do you think I have
1) a mechanical problem in the sender, OR
2) an electrical problem?
If you have seen this what did you do to correct it? What to check first?
Check the ground connection for rust or something foreign. On the half ton the wire which goes to the gauge has a connection in it under the cab. Sometimes corrosion gets in there. Emery cloth works wonders. You can also run a jumper wire from the power post on the sender to the gauge and see if it changes. If yes, there is a break or short in that line. You might also want to click the ignition switch on and off a few times. Been known to work - I do it all the time on my computer monitor!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Junior Member
Junior Member
So what I did was -- I took the float mechanism out of the tank and found that the float was filled with gas. I drained it out and epoxyed the hole. Now it works ok.
