1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I cleaned up aand painted a '53 cab to replace the one that was damaged when the Blue Funk was hit by a Semi last year.
I had to scrape off a thick black substance from the toe pan area in order to clean and paint it.
I've looked through some parts catalogs and the closest thing I came up with was in Jim Carter's called a Hush Mat that you can peel and stick.
Would this be what I need in order to replace what was there?
If so, I figure I only need about four square feet of it, and the smallest amount Jim Carter sells it in is ten square feet.
Can this item be purchased at a FLAPS?
Thanks. | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I put "Hush Mat" into my Search Engine and came up with this Starter Kit which is four square feet at a reasonable price.
HushMat Ultra Starter Kit - Black #10150 - Item is available. USD$ 35.95 Qty:
I just need to make sure this is the stuff I need.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have read post of some members going to lowes or home depot and usinging peel & seal I have not used it,so I can't give you a review but you can look into it maybe save a little coin. Good luck | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I used a roll of the reflectix (4x50) and a roll of foil tape and had enough to double up the floor, firewall, back wall and roof, plus a layer in each door. After dealing with paint flaking off the tar in the fender wells until I finally had to blast it, I'm not sure the next guy will like the idea when he starts removing it from the cab next time around.
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Thanksfor your replies, Gus, Caso.
I'll check your suggestions out and let you know the outcome.
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I ended up picking up some Evercoat Q-Pads from my FLAPS. They were about $30 for Foot Squares that came in a package of eight pads. They will do the same amount of area as what was originally on the toe pan and firewall with some left over.
Thanks for the sggestions. | | |
