| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | putting 235 engine in a 51 1300 pickup. is there only 2 parts to this mount ,the rubber and the thin shield? does the shield go on top of rubber or on the bottom? MJ Thanks in advance!!! | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Here's some info on hardware that I used when I replaced the motor mounts in my '54. My engine was not out of the truck, so I had to grind off the side of one of the carriage bolts. You may not need to if you have not installed the front plate on your engine yet, or if the original bolts are still in the plate. < CLICK > Motor Mount Thread
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | where can I buy these parts? don't see a web site on page to buy these from . maybe my computer cut the name off. thanks!!!! MJ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MJ, If you are referring to my link, that is Chevrolet Master Parts & Accessory Catalog. It has prices from 1957 and original GM part numbers. I do not think that all 4 front motor-mount parts are available in reproduction, but the front motor mount top cover/shield is available from Classic Parts and from other vendors (check the Links section of Stovebolt.com). Jim Carter might have more mount parts, but his site crashes when being viewed by my tablet computer. Classic Parts and many other vendors sell the rubber front motor mount. You might want call and check that the mount has metal bushings in the rubber, surrounding the two bolt holes. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I bought two pieces for my front motor mount from The Filling Station. Don't know if there is any difference between suppliers.
> Shield - GM #3656502; reproduction from Filling Station #TR-182 > Cushion Assembly - GM #3657520; reproduction from Filling Station #CV-335A > Plate - GM #3657522; reproduction may not be available. > Retainer - GM #368449; reproduction may not be available.
If you can't find a supplier of the plate and retainer, post a request on the Parts Wanted forum of Stovebolt.
