7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP), 111 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
V
VEW
Offline
V Offline
Bus is running really good....just trying to get it to stop now.
Pulled the rear drum yesterday and found two of the four return springs broken. I've looked for them at laps and a couple of other suppliers with no luck.
Can someone advise me where to look? O.D. is 1" and overall length is 3 1/4". Can't tell what color...maybe blue.
As always, thanks in advance.
Victor
~ Victor
1957 3100 - moved on
Riding in the Passing Lane
Napa catalog doesn't go back past 60 on that model. It shows 60 as part number 80169. The illustration section shows it as 3 1/8 long. It is fat in the center & tapers down on each end with a built in hook on each end. The color is grey.
1972 Chevy c10 Cheyenne Super
V
VEW
Offline
V Offline
Thanks for checking. NAPA has the shoes, but no springs.
It's not a barrel spring and has 12 turns in it with end hooks at 90 degrees of each other.
Jeff at Alretta is checking to see if he has any. I think I've exhausted all the resources I know of, but will keep looking.
Victor
~ Victor
Carquest catalog shows part # H-7270 for the complete kit.
V
VEW
Offline
V Offline
Thanks Wrenchbender. I'll check with the local store. Website does not go earlier than 1975.
~ Victor
U
U Offline
Hello. I am running into the same problem with my 59' Bus. I called carquest and the part number H-7270 is no longer available. What did you end up using?
Uncleherb
V
VEW
Offline
V Offline
I ended up having them made by a spring company in OH. I posted the info somewhere on this site. I'll try to find it and put it here.
~ Victor
V
VEW
Offline
V Offline
I used:
Timac Spring Manufacturing Inc.
825 Bellbrook Ave.
Xenia, OH 45385
(937) 372-3305
That was in Sept. 2012. Great service and great price. I sent them my old spring and they made 10 new ones...identical to what I sent. I think some other bolters have used them as well.
Good luck!
~ Victor
