6 members (jmoore, joe apple, Gdads51, 3B, Rusted Nut, 68ironhead), 112 guests, and 3 robots.
Topics128,264
Posts1,058,350
Members48,485
#872115 08/04/2012 5:56 PM
49 Sub, 283/TH350. During rebuild I installed new Dolphin gauges and speedo. 283 has a 180 thermostat and 7 pound pressure cap. The temp Gauge never reads more than 140. I am using the original 216 radiator after having it rebuilt by our local radiator shop. Also using an electric fan with manual switch. Even without the fan running it stays at 140. During our 4th of July parade I pulled a float over a 2 mile course at 96 degrees OAT. Still 140. It seems to me that with a 180 degree thermostat the gauge should read about 180 plus or minus. I used the sender that came with the Dolphins. The truck has never overheated. Any thoughts? Where should I start looking? I would really like this thing to read correct. Or is it actually running at 140? How can I tell its actual temperature? Any advice appreciated.
Weeds
Weeds #872122 08/04/2012 6:11 PM
I would pull the sender and put it in boiling water while watching the reading.
1951 1 Ton Completed
truckernix #872124 08/04/2012 6:20 PM
check around the engine, stat housing, rad top and bottom with a laser thermometer to find out what's really happening, I seriously doubt a good running 283 will be at 140* - and in addition to what nix suggests, check the thermostat in a pan of water on the stove, it may be always full open - a thermostat sets the minimum temperature, it doesn't allow coolant circulation until the water reaches it's rating
Flxible #872264 08/05/2012 9:20 AM
I'm with Bill, it's gotta be the gauge. pull the sender and put it in a cup of boiling water. Where is the sender mounted, thermo housing or head?
....David
