3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#87217 04/05/2003 2:54 AM
Thinking about getting away from the floor starter
for a while, how hard is it to switch to one of
these how input mini starters from the orig floor and if so are they expensive? mine is a 54
235 engine. thanks for any and all replys...Fred
Redryder pix
My Hotrod
Hello, if I remember correct all you will need is a starter from a car, a starter button to engage the solenoid attatched somewhere on the dash, or a different switch with the crank mechanism inernally. A few wires and connectors.
(Car stater approx same year.) Hope this helps.......Chb46
I just had my 6v starter rebuilt and the guy doing the work said if i wanted he would put a push button switch in the dash to by pass the foot start. This is an original out of my 53 pickup. He said 6v or 12v it doesn't matter it wouldn't be that expensive either. I would say to start find someone who works on them and ask.
Easy swap,car starter as mentioned before and use any early fifties GM car ignition switch. I used a 53 olds ignition switch in my 37 p/u,it fit the hole where the original switch was perfectly and run a wire from the start terminal to the cellinoid
It was done to mine. Don't get the universal ignition switch from the vendors it is junk. Find a GM one. I need one too.
54 3100 with 235
62 flatbed dump C60 with 261
I like th e hidden push-button idea for the non--foot-stomp starter
V
V Offline
Just go to any auto parts store and order up a starter for any '55 ~ '62 Chevy with a 235 and bolt it in , you'll be in like flint .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Not for nothin, there has been many discussions here about 6 volt and 12 volt flywheels and matching the proper starter, the 6 volt has less teeth on the starter ring gear.
Instead of changing flywheels,could the starter drives be switched. It has been a long time since I have had a foot operated starter apart but if I can remember correctly the starter drive or bendix as some call it look about the same. If it could be done it would be alot easier than changing the flywheel especially if its in a torque tube equiped truck. Jeff
Check your email, joker, I have a bunch of extra parts including a solenoid type starter from my 261.
Paint & Body Shop moderator
