| | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87217 04/05/2003 2:54 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Thinking about getting away from the floor starter for a while, how hard is it to switch to one of these how input mini starters from the orig floor and if so are they expensive? mine is a 54 235 engine. thanks for any and all replys...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87218 04/07/2003 9:35 PM | Joined: Nov 2001 Posts: 16 Member | | Member Joined: Nov 2001 Posts: 16 | Hello, if I remember correct all you will need is a starter from a car, a starter button to engage the solenoid attatched somewhere on the dash, or a different switch with the crank mechanism inernally. A few wires and connectors. (Car stater approx same year.) Hope this helps.......Chb46 | | |
#87219 04/08/2003 11:49 AM | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | I just had my 6v starter rebuilt and the guy doing the work said if i wanted he would put a push button switch in the dash to by pass the foot start. This is an original out of my 53 pickup. He said 6v or 12v it doesn't matter it wouldn't be that expensive either. I would say to start find someone who works on them and ask. | | |
#87220 04/09/2003 4:34 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Easy swap,car starter as mentioned before and use any early fifties GM car ignition switch. I used a 53 olds ignition switch in my 37 p/u,it fit the hole where the original switch was perfectly and run a wire from the start terminal to the cellinoid | | |
#87221 04/09/2003 6:54 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It was done to mine. Don't get the universal ignition switch from the vendors it is junk. Find a GM one. I need one too.
54 3100 with 235 62 flatbed dump C60 with 261
#87222 04/09/2003 10:12 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I like th e hidden push-button idea for the non--foot-stomp starter
#87223 04/09/2003 9:20 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Just go to any auto parts store and order up a starter for any '55 ~ '62 Chevy with a 235 and bolt it in , you'll be in like flint .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#87224 04/09/2003 10:01 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Not for nothin, there has been many discussions here about 6 volt and 12 volt flywheels and matching the proper starter, the 6 volt has less teeth on the starter ring gear. | | |
#87225 04/10/2003 1:05 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Instead of changing flywheels,could the starter drives be switched. It has been a long time since I have had a foot operated starter apart but if I can remember correctly the starter drive or bendix as some call it look about the same. If it could be done it would be alot easier than changing the flywheel especially if its in a torque tube equiped truck. Jeff | | |
#87226 04/10/2003 1:35 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Check your email, joker, I have a bunch of extra parts including a solenoid type starter from my 261.
