4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | have a 63 GMC k 10 bought it with no bumper..bought a bumper and brackets and the brackets look like they would bolt where the spring purches are mounted...she is 4x4 and has leaf springs...not coil like 2wd..anyone know if brackets are avalable...anyone have them?? Could u send me pic???.. | | | | | Joined: Apr 2012 Posts: 13 New Guy | | New Guy Joined: Apr 2012 Posts: 13 | I have a 63 GMC K20 and have run into the same problem. If you get photo will you please post them?
Holl | | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | Sure will...not a problem!! | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | should bolt onto the end of the frame 2 bolts on either side and the bracket goes back to just in frt of the steering box and the same distance back on passenger side. it is possible being a 4 x 4 that the ends of the frame were cut off to perhaps mount a winch bumper or whatever. I do have a set of frt frame ends the frt bumper mounts as any other c10-c20 bumper mounts irregardless of what suspension it does have ron | | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | Im sorry I was refering to the rear bumper sorry should have made that clear. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you may have to relocate some holes or find a set of GMC C10 rear bumper brackets ron | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | We have several '60-'66 Chevy/GMC 4x4 trucks. The rear bumper brackets mount on the vertical web of the rear frame rails. Hit me with an e-mail and I will send some photos of the install.
| | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Heidel, which brackets do you think you have with your bumper? I presume step side? Tony is the 4x4 bumper same as C-series? Reason I ask - I am getting closer to needed rear bumper and brackets for 62 fleet. HB | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | HB, the fleetside sport bumper on the 4x4 (K10 & K20) trucks are the same, as those found on the 2wd (C10 & C20). The same is true for the stepside sport bumper on the 4x4 (K10 & K20) trucks & the 2wd (C10 & C20). This applied to both Chevrolet & GMC.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Good to know. I will be able to broaden search. | | | | | Joined: Dec 2006 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 56 | HB step side is correct short bed step side...Tony I sure could use a pic | | |
