0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#870854 07/31/2012 10:03 AM
have a 63 GMC k 10 bought it with no bumper..bought a bumper and brackets and the brackets look like they would bolt where the spring purches are mounted...she is 4x4 and has leaf springs...not coil like 2wd..anyone know if brackets are avalable...anyone have them?? Could u send me pic???..
heidel410 #870859 07/31/2012 10:13 AM
I have a 63 GMC K20 and have run into the same problem. If you get photo will you please post them?
Holl
holl #870866 07/31/2012 10:37 AM
Sure will...not a problem!!
heidel410 #870885 07/31/2012 12:04 PM
should bolt onto the end of the frame 2 bolts on either side and the bracket goes back to just in frt of the steering box and the same distance back on passenger side.
it is possible being a 4 x 4 that the ends of the frame were cut off to perhaps mount a winch bumper or whatever. I do have a set of frt frame ends
the frt bumper mounts as any other c10-c20 bumper mounts irregardless of what suspension it does have
ron
padresag #870904 07/31/2012 1:08 PM
Im sorry I was refering to the rear bumper sorry should have made that clear.
heidel410 #870906 07/31/2012 1:16 PM
you may have to relocate some holes or find a set of GMC C10 rear bumper brackets
ron
padresag #871286 08/01/2012 5:15 PM
We have several '60-'66 Chevy/GMC 4x4 trucks. The rear bumper brackets mount on the vertical web of the rear frame rails. Hit me with an e-mail and I will send some photos of the install.
Sent ya a pm
heidel410 #872028 08/04/2012 10:05 AM
Heidel, which brackets do you think you have with your bumper? I presume step side?
Tony is the 4x4 bumper same as C-series?
Reason I ask - I am getting closer to needed rear bumper and brackets for 62 fleet.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #872092 08/04/2012 4:41 PM
HB, the fleetside sport bumper on the 4x4 (K10 & K20) trucks are the same, as those found on the 2wd (C10 & C20). The same is true for the stepside sport bumper on the 4x4 (K10 & K20) trucks & the 2wd (C10 & C20). This applied to both Chevrolet & GMC.
Good to know. I will be able to broaden search.
~ HB
1962 Chevrolet C10
1962 Suburban
HB step side is correct short bed step side...Tony I sure could use a pic
