7 members (Jon G, ShopRag, Bill Hanlon, Waveski, KEVINSKI, 52Carl, Wrenchman), 70 guests, and 5 robots.
Topics128,262
Posts1,058,331
Members48,485
#871562 08/02/2012 2:07 PM
Ive been tryin for hrs to get carrier bearing off front shaft. comments and tips wanted. do i need to take to shop, and Napa replacement looks alot smaller.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
I've done them before on newer trucks at a shop I worked at and they were a dangerous beast. Had to put them in a HD shop press, go as tight as I could press it, then walked out of the room, closed the door and waited. About a minute later you would hear it release, violently. Walk back in the room and collect all the peices scattered about. They always press back on easier though. So be careful!
1953 1 ton panel
Thanx pooter, what I lack in taent I make up for in determination, I called a local shop he told me he cuts them off with torch so back out to the shop I went. With a little more heat and some heavy pounding, I got it off and did'nt cut it off.The replacement from Napa is not as thick but right diam.Thx again.
More pix on Flickr
? about dust covers, OEM won't work with replacement bearing. Are they needed has anyone replaced bearing without covers. Other sites say no need to worry.
More pix on Flickr
Shouldn't need one with a sealed bearing.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Thx trucknut, checked american classic they have what looks like oem so i ordered thiers and will take back napa's. Few dollars more but i'll feel better. That 10% savings with AC is great been tearing up orders with them.
More pix on Flickr
Moderated by  Dusty53
