| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Ive been tryin for hrs to get carrier bearing off front shaft. comments and tips wanted. do i need to take to shop, and Napa replacement looks alot smaller. | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | I've done them before on newer trucks at a shop I worked at and they were a dangerous beast. Had to put them in a HD shop press, go as tight as I could press it, then walked out of the room, closed the door and waited. About a minute later you would hear it release, violently. Walk back in the room and collect all the peices scattered about. They always press back on easier though. So be careful!
1953 1 ton panel
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thanx pooter, what I lack in taent I make up for in determination, I called a local shop he told me he cuts them off with torch so back out to the shop I went. With a little more heat and some heavy pounding, I got it off and did'nt cut it off.The replacement from Napa is not as thick but right diam.Thx again. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | ? about dust covers, OEM won't work with replacement bearing. Are they needed has anyone replaced bearing without covers. Other sites say no need to worry. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Shouldn't need one with a sealed bearing.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thx trucknut, checked american classic they have what looks like oem so i ordered thiers and will take back napa's. Few dollars more but i'll feel better. That 10% savings with AC is great been tearing up orders with them. | | |
