| | | Forums66 Topics128,181 Posts1,057,189 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | Bus is running really good....just trying to get it to stop now.
Pulled the rear drum yesterday and found two of the four return springs broken. I've looked for them at laps and a couple of other suppliers with no luck.
Can someone advise me where to look? O.D. is 1" and overall length is 3 1/4". Can't tell what color...maybe blue.
As always, thanks in advance.
Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Napa catalog doesn't go back past 60 on that model. It shows 60 as part number 80169. The illustration section shows it as 3 1/8 long. It is fat in the center & tapers down on each end with a built in hook on each end. The color is grey. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | Thanks for checking. NAPA has the shoes, but no springs. It's not a barrel spring and has 12 turns in it with end hooks at 90 degrees of each other. Jeff at Alretta is checking to see if he has any. I think I've exhausted all the resources I know of, but will keep looking. Victor
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Carquest catalog shows part # H-7270 for the complete kit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | Thanks Wrenchbender. I'll check with the local store. Website does not go earlier than 1975.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2015 Posts: 13 New Guy | | New Guy Joined: Mar 2015 Posts: 13 | Hello. I am running into the same problem with my 59' Bus. I called carquest and the part number H-7270 is no longer available. What did you end up using?
Uncleherb
| | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | I ended up having them made by a spring company in OH. I posted the info somewhere on this site. I'll try to find it and put it here.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | I used:
Timac Spring Manufacturing Inc. 825 Bellbrook Ave. Xenia, OH 45385 (937) 372-3305
That was in Sept. 2012. Great service and great price. I sent them my old spring and they made 10 new ones...identical to what I sent. I think some other bolters have used them as well.
Good luck!
