3 members (GMCJammer51, Jon G, Gray_Ghost), 120 guests, and 5 robots.
Topics128,078
Posts1,056,046
Members48,433
#87169 04/09/2005 7:31 PM
Junior Member
Junior Member
Gentlemen,
I am rebuilding a ’58 261 engine to put in my 50 Chevy 3100. The engine came from the bone yard with a later model Delco Remy distributor (1110318) for the 194/250/292 series engines. How can this be? I thought the later model 194/250/292 distributors would not work in the 235/261 series engines. I have closely examined the distributor and cam drive gears and see no adverse wear patterns. The ’58 Chevy shop manual shows a different distributor with the vacuum advance located on the block.
Very confused in Colorado Springs.
Bill in Colorado
#87170 04/10/2005 9:47 AM
That seems odd to me, but I do know that the later distributors can be modified to fit in the 235/261. You can use a 235 dist. in a 261 if you are worried about it.
Paint & Body Shop moderator
#87171 04/11/2005 9:25 PM
"MONGO"
"MONGO"
I've read over on the inliners site that this can be made to work, they recommend "If you compare the drive tang on the old distributor with the HEI, you'll see that they are slightly different. The HEI will engage the oil pump and work - but it's a good idea to massage it a little with a file or dremel grinder, for a perfect fit. It might make the difference if the clamp loosens up and the distributor wants to jump out. Good insurance for a few minutes extra work." Also sounds like you'll need some kind of clamp to keep it in place. And you'll wanna smear some RTV sealer around the shaft so it doesn't leak.
I've not done this but have read about it over there.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#87172 04/11/2005 11:52 PM
Bill,
I have a 235 dizzy if you need one for re-build.
I'm up the road in Elizabeth.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
