Taken a shot in the dark here, Do You play video games?
This is a case of taking the skills you learned in Mortal Kombat and translating them into Battle Field or COD... Or PacMan?
Push Rods, Pistons,Wrist Pins and Cranks. Rockers, Sparkers, Carbs and Valves
Only the numbers change to perplex and amuse but the function remains the same.
Read the manual
The Manual , translate what the video shows you into your new top of the line VIRTUALLY REAL 4D!terrain/enginescape(Maps are location specific to
Your Garage!),
Be sure to use the setup menu in the version.01model of the game (see link) then just remember to set your equipment for the new specs and squeeze the triii No wait that's pushhh the buttonNoImean turn the wrench!
I think figgerin out the difference's between engines was like figgerin out.... well let just say, some things just take figgering out, and we can leave it at that.
If your not a gamer I apologize I mean no disrespect...
(For the record I am Not a Gamer but They have sprung forth from my loins
So I've watched a game or two)
