0 members (),
119
Mod | | | Forums66 Topics128,088 Posts1,056,416 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Being new at most everything related to this truck, I simply unbolted the old non-functioning mechanical fuel pump on my 1965 230ci inline 6. A few minutes later I had my new fuel pump bolted onto the engine block. Simple, right? Apparently not! I found out tonight that it just isn't pumping fuel. I put my finger over the intake side while cranking the engine and it doesn't have any suction. I looked through the FSM but I think I need more help. Anyone? http://i618.photobucket.com/albums/...20Chevy%20C10/fuel%20pump/0721121717.jpg
| | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | First, check to see that the camshaft lobe that operates the pump isn't worn out. Remove the pump, and have someone tap the starter as you shine a bright light into the hole. There should be a noticeable high spot visible as the cam turns. If the shaft is round, or showing extreme wear, it's time to change the cam. It's also possible you've simply bought a non-functional new pump. Push the pump operating rod down against the workbench top and see if any vacuum is developed at the inlet port. It's either a bad cam or a bad pump, or possibly both, but that would be pretty unlikely! Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | So I assume there is no special connection or way to position the fuel pump. Right? Originally, i assumed that if I bolted it onto the block correctly, then it should contact the cam and work.
This evening I'll pull it off the block and use a mirror to look inside to see if that cam looks rounded off. I kinda doubt that is the case since the engine only has 88k miles. I'll post an update. Thanks | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Straight 6-cylinder pumps go on with the in and out connections on top...which is 'upside-down' compared to a V-8. Ask me how I know.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I'm working on a Jeep CJ5 with a 304 V8 and had the same problem... No fuel to the pump... so I bought a new pump. Still, no fuel to the pump. To make a long story very short, yes, check the action of your pump. You can even manually push the pump lever to see if it's sucking with your finger over the inlet... But my problem wasn't the pump... and by the way, I still have my old pump as a good spare! For me, there was a rubber fuel line that was clamped well but in not that great of shape. Though it wasn't showing any leakage I guess it breathed, not allowing a good suction. Try drinking from a straw with a split in it... I replaced the rubber line and it solved my problem. 2 cents worth... Good luck, Jerry W | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | First, thanks to all who took an interest in helping me solve this problem. I really appreciate it. First, check to see that the camshaft lobe that operates the pump isn't worn out. Remove the pump, and have someone tap the starter as you shine a bright light into the hole. There should be a noticeable high spot visible as the cam turns. If the shaft is round, or showing extreme wear, it's time to change the cam. It's also possible you've simply bought a non-functional new pump. Push the pump operating rod down against the workbench top and see if any vacuum is developed at the inlet port. It's either a bad cam or a bad pump, or possibly both, but that would be pretty unlikely! Jerry Jerry, you were right! I removed the fuel pump and it tested OK by hand. I could feel it suck at the inlet and I could make it suck gas out of a gas can by hand pumping the lever. Here's a picture of the cam lobe. And another picture. It has a groove down the middle and after tapping the starter a few times, it appears to be round in the middle where it contacts the fuel pump. Finally, I bolted the fuel pump back on and it will not pump gas and has no suction when I crank the motor. The PO had hooked up an electric fuel pump and bypassed the mechanical. Now I know why. I had always assumed it was because the mechanical fuel pump went bad. What all is involved in replacing that cam and should I consider just using an electric fuel pump instead? Does that cam have any other function? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the pump lobe just runs the pump .... you don't want to replace the cam, especially if you already have the electric pump
Bill | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | the pump lobe just runs the pump .... you don't want to replace the cam, especially if you already have the electric pump
Bill Thanks Bill. I guess it'd be a lot of work. Shucks, I guess I bought a $50 mechanical fuel pump for nothing. The electric fuel pump I have is made for carburetors and has about 4 to 7psi if I recall correctly. I'm kinda surprised that the lobe on that cam is rounded off with only 88k miles on the truck. It makes me wonder if it might have 188k or possibly my odometer cable broke at 88k and it has a lot more than that. Anyone ever see a fuel pump cam wear down with mileage of less than 100k?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends how often the oil was changed, and on how long it was run low on oil  Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Seems like there is still enough to operate the pump.Did you install the pump in the right position ?
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | You asked if there is a "special connection", and mentioned "if I bolted it onto the block correctly, then it should contact the cam and work". I really know nothing about the 6 cylinder motors, but I assume there is a pushrod for the fuel pump? Is the pushrod present? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | You asked if there is a "special connection", and mentioned "if I bolted it onto the block correctly, then it should contact the cam and work". I really know nothing about the 6 cylinder motors, but I assume there is a pushrod for the fuel pump? Is the pushrod present? From all of my observation and reading, it appears that the inline 6 engines have a fuel pump that operates by a cam that presses on the lever on the back of the fuel pump. There is no connecting rod (as I've been told exist on V8s.) I think the pump is installed correctly, just wasn't sure that it was until I pulled it all apart, tested it, and reassembled everything. Here's a picture of the pump showing the lever.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | That lobe looks ok. From your photo it is hard to tell if the lobe is rounded or not. I took the oil pan off a 261 last night and the pump lobe looked just like that. I had to take a closer look to see the lobe was indeed good to go.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | Yes, the V8s use the pushrod. Thus my disclaimer about not being familiar with the inline 6. Always good to learn something new. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Drum roll... Was this resolved? Jerry | | |
