Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#871304 08/01/2012 6:21 PM
if I'm shopping for a Borg-Warner OD to put in our truck, do I need to get an entire transmission or will the B/W bolt onto the existing tranny?
'58 Apache LWB, 96,000 mile unrestored original;
'31 Ford Coupe, 22,000 mile unrestored original;
'31 Ford SW Town Sedan.
you need the whole thing
Flxible #871442 08/02/2012 2:23 AM
and a solenoid, kick down switch, governor, relay, and shifter ( i guess they dont make a floor shifter to fit it anymore,) lol i tracked down 2 trannys and 1 solenoid, but i still need the switch, relay, shifter.
drew_vigil #871501 08/02/2012 10:29 AM
You can use a variety of aftermarket kick down switches and relays. You don't need to pay for the overly expensive original stuff on ebay. They can be found at Napa and also pick your part.
Fred
rfs56trk #871525 08/02/2012 11:58 AM
I wired mine with a Bosch relay and a DPDT toggle switch.
Diagram
drew_vigil #871542 08/02/2012 1:04 PM
MisterR #871678 08/02/2012 10:22 PM
no thanks, don't want a floor shift conversion.
part of the fun of driving it is the column shifter!
Those floor shift conversions generally will not work with the overdrive trans anyway. The solenoid gets in the way.
Bill Burmeister
