Ok folks, I am sorry for asking this question that had been asked to death, I have searched other articles...............BUT, I am not completly clear on everything that is invloved with the change over from a generator to an alternator.
I am aware that the alternator has a built in voltage regulator and the one on the firewall is no longer needed. My 54 already has the 12 volt starter, coil and lights installed on it.
What I am confussed with is, what does the ammeter need to make it work correctly? Do I need a SHUNT? EXACTLY where do all these wires go that was once used on the regulator? I know that one wire goes to the battery (No brainer) and a couple that came from the generator, so these two I assume can be taken out and disgarded.
I've seen an article last night something about a
BALLAST RESISTOR and then a
VOLTAGE RESISTOR are they not, two of the same? I already know that I must have a resistor on the fuel gauge, to drop it down to 6 volts. I still have the instrument cluster out of the 60 school bus (another saga story in an earlier post) that I could use the ammeter out of, if need be. I have the alternator and the brackets to mount it on my engine from the old bus.
Please bare with my stupidity. I wasn't even going to change over to the alternator system, but the other night I had the headlights on and the heater on low speed the ammeter was really on the discharge side almost pegged sitting at a stop light and then running at normal town driving speed (30 MPH) it was still showing on the dishage side. I shut off the heater and it jumped on over to charge, to the first line on the plus side of the ammeter, I thinking it was at 15 amps or there abouts.
Is there an easy to follow schematic, that someone can point me to?
AGAIN, sorry for the dumb question, but you all have been so helpful with project. One just has to love this site.
John Niekamp
http://www.geocities.com/jniekamp/
