4 members (1955 1 Series, mason86, moparguy, MNSmith), 103 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#850321 05/10/2012 6:34 AM
Hi, my name is morgan, I am 26. I am from a small hick town in SASKATCHEWAN CANADA. I am married and have two daughters. I am welding apprentice, work on my friends farm during seeding and harvest. I recently bought the equipment to do mobile tractor tire repairs.
So I needed a new truck that would handle the weight of my tools, welder and up to 200 gallons of calcium chloride to fill tractor tires with for traction.
Morgan_Horn #850322 05/10/2012 6:40 AM
I had recently fallen in love with my friends dads 64 1 ton and thought I would look for one similar. Well I found our local towns old firetruck parked at a farm still in good condition. It's either a 58 or 59, not sure, did not run the serial number. But it seemed to be in good shape and was running 5 years ago, had a new tank put in ten years ago and 2 new tires as well. So I bought her for $500, currently in the middle of seeding crops so don't have time to pick her up yet.
I will be building a new flat deck so I can mount my homemade portable welder, tool boxes, and tires.
[IMG]http://i947.photobucket.com/albums/ad319/astro_ss_340/gmc1.jpg[/IMG]
[IMG]http://i947.photobucket.com/albums/ad319/astro_ss_340/gmc2.jpg[/IMG]
Morgan_Horn #850335 05/10/2012 11:36 AM
Morgan,
welcome to the Stovebolt. I think you will find this site a great place for all your truck needs. There are a lot of us here that are that are old truck crazy!
I see that your truck appears to be really solid. I am guessing that they don't use a lot of salt on the roads where you are. That is not the case in Ontario and so truck projects usually come with a lot of rust!
1951 1 Ton Completed
truckernix #850353 05/10/2012 12:58 PM
Morgan,that's a nice looking truck but I noticed someone put a big truck bumper on it.I like the look but I would take a section out of each end and shorten it.That's a real knee knocker the way it is.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
tntrucknut #850627 05/11/2012 6:35 AM
Ya that big bumper needs to be shaved. As for the salt, it was a fire truck all its life, so it was always washed after it was taken out. So it was very little rust on it. I did notice that the drivers door "top" hinge is a little buggered. That and the seat are about the worst of it.
Basically I will get her mechanically sound, build my flat deck, mount my equipment, take off the old fire dept logo and get a new one painted on....made to look old. Might just leave the body and paint, or do it at a later time......this truck will actually be used as a work truck, like it was orgionally intended for. I can't wait!
Morgan_Horn #850628 05/11/2012 6:37 AM
Where can a guy buy 18" tires for this truck? I know COKER sells STA brand 18's but is there any other company?
Morgan_Horn #852084 05/17/2012 5:23 AM
http://s947.photobucket.com/albums/ad319/astro_ss_340/?action=view&current=idea.jpg
This is what I am thinking for an old school deck for it
Morgan_Horn #853955 05/25/2012 5:47 AM
Morgan_Horn #853958 05/25/2012 5:53 AM
http://i947.photobucket.com/albums/ad319/astro_ss_340/P5231366.jpg
Finally got her home today. Pulled the flatdeck off, removed all of the angle iron mounts that were welded to the frame to hold the deck down. Wow someone did not know how to weld ahahahaha.......I ground half of the bead off of one side of each angle iron.....hit it with a one pound hammer and cracked that weld, then took a big pipe wrench and twisted the angle irno side ways thus removing the pieces. Gotta love being able to crack a weld with a wrench ahaha.
Pulled the carb off, pretty clean inside, gaskets are good. Will wash the sediment out of the bowl.
Also took the mouse nests out, pulled the seat, just gotta buy a broom to clean the floor as my wife would kill me if I used hers to sweep it out.
So far so good, glad to finally have it on my property,
Morgan_Horn #854327 05/27/2012 1:56 AM
My one ton is alive!!!!
Morgan_Horn #854693 05/28/2012 6:59 PM
Sounds good, oil them hinges up before you use them to much, poke some rags in the seat and cover it with a horse blanket cover and go for a ride LOL. Seriously that is a good find and should look good with all the equiptment on it.
You Learn more Listening than Talking
Spareparts2 #862062 06/26/2012 6:12 AM
http://i947.photobucket.com/albums/ad319/astro_ss_340/P6221396.jpg
got a flat deck for it, cleaned it up a little bit, mounted it, plated the sides and cut the corners up front, started on a headache rack, mounted my new seat, had to remove the fuel tank to fit it in properly. Just have wiring and tie rod ends to do now, then I will be out doing mobile tire repairs in my small farming community
Morgan_Horn #868437 07/21/2012 11:23 PM
http://s947.photobucket.com/albums/ad319/astro_ss_340/?action=view&current=P7191452.jpg
Got my welder with air compressor on, 30 gallon air tank, put a 15 gallon saddle fuel tank on it,some tool boxes, and the best addition was a new 2n1/4 exhaust to a 3" stack! She sounds mean as heck and even like a small block diesel. I think Screamin Jimmy will be an appropriate name for it.
Morgan_Horn #871288 08/01/2012 5:28 PM
I like it. It's looking good so far.Larry
58 gmc 100 with 350 sbc
Moderated by  Dusty53
