2 members (2-Ton, Jon G), 152 guests, and 2 robots.
Topics128,167
Posts1,057,017
Members48,458
#869926 07/27/2012 6:20 PM
Custom Title
Custom Title
Hey guys, just wondering what size tires fit and look the best on a 3/4 ton AD? I want to get modern LT radials but I don't want to end up with clearance issues. I have a set of 16" wheels off of a Dodge that I will using to get away from the split rims. Any input is appreciated
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
I have 16" Yokahama tubless radials on my 51 1 Ton. The truck is a pleasure to drive and steers very nicely. I have 80s rims that are 6" wide. The tires are labelled as R215 but they are fairly tall.
1951 1 Ton Completed
I put 215 85 r16 on my 50 3600 with no clearance issues.
1950 Chevy 3600
Custom Title
Custom Title
Happen to have a pic of it? Just curious to see how it looks
49 Chevy 3600
65 Chevy K10
Here is what my truck looks like with the tires. 16" radial tires
Just put these on yesterday, 235/85/16. Sorry for the dark picture, the sun wasn't cooperating with me.
http://i629.photobucket.com/albums/uu20/kevin92xj/photo19.jpg
1953 1 ton panel
I have 265 70 R16's on my 1949 Chevy 3600. Worked out good, on Ford 8 lug steel wheels.
I have Michelin LTX M/S LT 235 85 R16's on 8lug mags on my 51'GMC 3/4. Looks and drives great,but I have some rubbing on the drag link on hard lefts.I'am thinking of flipping the drag link and putting the short end on the pittman arm and see if that helps.
Custom Title
Custom Title
Thanks guys... Sounds like 235/85 is a good choice
49 Chevy 3600
65 Chevy K10
Not yet! "Southtowns27" I have a 51' GMC 3/4 with the original style draglink "New" from "He who will remain nameless motors"and having a interference problem on left hand turns.I don't want to recomend this size tire,until I have my own problem/problem's solved.
What backspace are you running on your wheels? I've seen this problem pop up when fitting non-oem wheels to the '59 and older trucks, and wheel backspace seems to be one of the culprits.
Bill Burmeister
16" Commercial TA's 90's Suburban 3/4 ton wheels with original hubcaps fitted. Love the ride and looks original.
http://good-times.webshots.com/photo/2071318780102454676foVBMK
The backspacing of the wheels I have are 4.25" from the mounting flange all the way to the very inner edge of the wheel. The tie rods clear about 1/4" so I threw a 1/4" spacer in as well for good measure.
1953 1 ton panel
Thanks! If I'am following you guys right,"Long box /Pooters"! (Backspacing) is measured from the wheel hub where it meets the hub/brake drum to the inner edge of the wheel not the tire? I pulled a wheel today and I'am about where Pooters is at 4.25. I think,but not sure these are American Racing 8 lug mags. Add to that the tire Michelin LTX M/S 235 85 R16's and I'am closer to 5.
Technically, backspacing is measured from the mounting flange to where the tire seals on the rim. But since clearence is our issue, I measure to the inner edge of the wheel.
1953 1 ton panel
Most manufacturers do go to the flange for the backspace dimension, depending on wheel design, but you've got the right idea. 4.25 is about 3/4" too deep, 3-3.5" is about the most backspace these trucks can handle without rubbing issues.
Bill Burmeister
3/4" is exactly on (left hand turns),that my OEM/style drag link wants to bite into the sidewall. Do you think going to a modern type drag link would gain any clearance? Thanks Jimmy
Hello All, one quick questiion, What wheel have you folks found to replace the OE split rim? The F**d 1970's vintage? to fit with out tie rod end interference?
1951 3600 PU.
Please advise,
Dave
The only ones I have heard of that fit without some modifications are a trailer wheel. The Ford/Chevy 3/4-ton moderns will not fit without some tweaks.
I have what I beleive is a 70's vintage F**d wheel with a 1/4" spacer. I beleive mine has more modern tie rod ends too. But it all seems to fit fine on mine.
1953 1 ton panel
'70s-'80s Dodge van wheels will work without any issues.
Bill Burmeister
I originally installed American Racing wagon wheels-8 lug 15 inch and ran LT 235 75s.
Photo is on Olblue's facebook
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
Is anybody else using these particular wheels?
Are there any others that fit without any issues at all?
Thanks.
1950 3/4 ton
1946 1/2 ton
1946 3/4 ton
1946 1 ton
1941 1/2 ton
