3 members (UtahYork, Millenimech, klhansen), 168 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#8709 03/16/2004 5:04 PM
hi does any of you know if an original starter out of a 56 chev truck straight six 235 engine will bolt into a 56 chev truck original v-8 bellhousing.thanks
#8710 03/16/2004 8:11 PM
LT Offline
My recollection is a little rusty, but I don't think your 235 starter will work with the v8 bellhousing. Hopefully, somebody else will chime in here because I have only 70% confidence in my answer.
#8711 03/17/2004 3:56 AM
Swap your front housing and it should work. Actually you can do this with very many General Motors starters. You might want to sand the commutator and put in new brushes while it is apart and put a little grease in front and rear bushings.
Truck Tinker from Talking Rock, Ga.
#8712 03/17/2004 6:21 AM
no - 6 cyl starter is foot stomp and v8 starters are solenoid [key switch] operated
