| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | hi does any of you know if an original starter out of a 56 chev truck straight six 235 engine will bolt into a 56 chev truck original v-8 bellhousing.thanks | | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | My recollection is a little rusty, but I don't think your 235 starter will work with the v8 bellhousing. Hopefully, somebody else will chime in here because I have only 70% confidence in my answer. | | | | | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | Swap your front housing and it should work. Actually you can do this with very many General Motors starters. You might want to sand the commutator and put in new brushes while it is apart and put a little grease in front and rear bushings.
Truck Tinker from Talking Rock, Ga. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no - 6 cyl starter is foot stomp and v8 starters are solenoid [key switch] operated
Bill | | |
