7 members (chevy51truck, Gdads51, dt235sd, Otto Skorzeny, JW51, MickeyP, LAROKE),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,698 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I'm restoring a 1953 3100 and during restoration I removed the doors and the hinges on each. I did not mark the hinges on removal and was wondering if the upper and lower hinges are different. Does it make a difference what hinge goes where? I can't seem to get the doors to align. If they are different, is there a way to tell which hinge is the upper and which is the lower? Thanks for your help.
1953 3100 Chevy 5 window 1971 Chevelle SS
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Upper ...lower... Compare pics, you can see the difference | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | pictures tell it all but the top hinges also are the ones what have the "door check" horseshoes in them. | | | | | Joined: Sep 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 78 | I see the difference now. Thanks for your help.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | All four hinges are unique and can only go in one location. | | |
