0 members (),
46
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Wondering if someone out there has had good experience with a certain brand and part# spark plug. I checked the Champion website and they offer no plug for a 216 application, at least as far as I can tell. Surely there is a plug out there that has the correct heat range for regular ol city driving. Thanks. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Depends some on the year model 216. Some had a smaller (10mm) threaded plug if I remember correctly. If it is a standard 14mm plug then AC R45 should be a good plug for that engine. Champion Number would be RJ8C. Autolite is 303 | | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Thanks for the info. Getting harder to find resources that show fitment. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its a good idea to use thr extended tip plugs. Like R45S in AC or the equivalent in the other brands. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Why? R45 work great, and I have been told the extended tip could cause issues with pre-ignition. Don't need holes burnt in piston. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have tried several brands of plug and have had the best run out of AC. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The extended tip plugs run cooler then the recessed tips. The tip is out in the comp. chamber & the gasses flowing by cools it. When the ext. tip came out in the 60's all the car cos. immediatly started useing them as original equip. Except on flatheads. The only reason the old manuals dont show them because they are reprints from the original. I have been useing ex. tip plugs for 50 years on every thing I have serviced except flatheads, & have never blown a piston. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | +1. Plus, wih the low compression of the 216 I really cant see how detonation could ever be a real problem with modern fuels. Unless of course the timing was WAY off (advanced). I recently purchased 1964 Corvair Monza Spyder Convertible (been sitting for over 25 years, still not running as I am going through the fuel system now). The turbo corvair engines are VERY suseptible to detonation and most of the Corvair gurus (and major part suppliers) recommend the extended tip spark plugs. Just sayin.... | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I'll have to disagree, but it's your engines, not mine. So long as you haven't had a problem, keep doing it. | | |
